ABS activation at ALL speeds, the usual sensor/hub problem!
Bigcatfishking
Update: After all brake lines have been replace ALL ABS troubles are gone! No more DTCs etc. Strange because I still don't see the connection but somehow it works!
That’s great I had been having brake line problems also. When I bought the truck I had to replace 2 lines. I’m wondering if that’s my issue also.
Bigcatfishking
Yes, he figured his issue out. You didn't see it in post #17? And the OP hasn't been back here since the end of August.
I would recommend that you research the diagnostic path for each/all of the codes you have, as your issue may have a different cause.
No I didn’t see op had fixed issue. I’m just gonna take it to a shop. Thanks for the info.
jorgecoronado7
