blown240
- Joined
- Jul 11, 2017
- Posts
- 79
- Reaction score
- 55
I just bought an 04 Yukon XL. It has the ABS light, and the brake light on. I went and had it scanned and came up with these codes:
P0719
P0856
P1689
From my research I found this info:
P0719 - Brake Switch Circuit Low Input
Possible causes Faulty Brake Switch Brake Switch harness is open or shorted Brake Switch circuit poor electrical connection
P0856 - Traction Control Input Signal, P0856 means the traction control input signal is not functioning properly, possibly due to a faulty ON/OFF switch or defective connectors.
P1689 - Traction Control Delivered Torque Output Circuit Conditions. GMC Description With the engine speed over 500 rpm, T/C system has failed, engine runtime 20 seconds and no Delivered Torque Output signal were received.
So where do I start? The truck seems to drive totally fine, and there is no check engine light, just the ABS and Brake lights are on.
P0719
P0856
P1689
