Abs and Parking Brake light
mpope2
I agree with several other members, it’s the solder welds on the ABS module causing the issue. Great suggestions from all on removing and reflowing the welds. Dorman also sells remanufactured control modules. They vary from 2wd, 4wd, awd, and traction control equipped models. It’s also not a bad idea to clean up the driver side ground as one member mentioned as well.
morecowbell509
