ABS light strange behavior
yuk
'96 Yukon, SLT 2 door. 350 Vortec, 140K.
The ABS light comes on after moving forward a few feet just after startup. I hear a small grinding sound, maybe coming from up front somewhere. Happens everytime EXCEPT when in 4wheel Hi. I can change into 2Whl after say 5 secs of forward motion, and the ABS light will not come on. The only time ABS light appears is if I start out in 2Whl.
I realize there are codes, but they want 50 smackers just to tell me what they are. I'm wondering if someone here has insight into what these clues could indicate. Thanks.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
it is best to remove the front abs sensors first and check for contamination first. There is a method to possibly pull abs codes yourself. I believe it was grounding wire the tan/white wire on the dlc connector to ground, turn ignition on and read abs light flashes. at your own risk since you are a 1996 model. report back any codes hear.
lordmorgul
