ABS problem help!
kjlegend
Milwaukee
After doing some engine repairs my ABS keeps kicking in even on light braking. I pulled the ABS fuse and it stopped however I dont want to ignore the problem or have the ABS light flashing anymore.
The repairs consisted of:
New distributor
Cap/coil/rotor also
Crank pos sensor
Fuel Pump
Plugs/Wires
Alternator
Battery
Basically ignition system work, and fuel pump...Nothing to do with the braking system at all! Why/how could this have happened?
I did most of the work myself and the rest was done by my personal friend/mechanic so I dont know if possibly something was broken while we were under the hood?
Any ideas or suggestions need
ravingmadman
Chief Knuckle Buster
Greater Seattle
I'm going to go with unrelated, but you might have a wire harness loose, or something. I need to buff up on my Hoe ABS stuff.
dacpdx
