AC Charge
malones99
I have a Yukon and my father in lay has a 99 suburban. When I turn my AC on in the Yuk the compressor "click's" on. In the sub, no click. He was having problem last year and had a shop recharge it. My question is if the r-134 is low, will that prevent the compressor from clicking on? or could it be a fuse or relay?
malones99
malones99
Thanks 718!!!!! Do you happen to know how many cans of AC a suburban takes, it say 3lbs. 8oz.
718frankb
LOCAL 282 TEAMSTERS
BROOKLYN,NY
no idea how many cans all i know is be carefull not to over charge it . 1 can should get you going maybe half of a 2nd- good luck
ravingmadman
Chief Knuckle Buster
Greater Seattle
The compressor won't kick on without pressure to keep it from burning up. I wrote a how-to on all of that. Check out the tech section.
malones99
malones99
Excellent writeup! I will try after work today!!!!!!!
99Yukon_Z71
Crazy Puerto Rican
Humble, TX
The burbs take 4 cans. Just monitor your low side pressure if you dont have the manifold gauges to monitor high side pressures.
Jeremytahoe
