AC Delco O2 Sensor
Ruddbow
I am replacing the the O2 Sensor, Bank 2 Sensor 1 (passenger side, Pre Cat) and want to order the correct AC Delco part. There are a few options. I have the 4L60 Transmission and the VIN eighth digit is an "R". I am attaching a pic for clarification. Thank you for your response(s).
LI99HOE
Top Notch Tech.
N.Y.
The temp. dropped below 40 degrees here, so my truck threw the P0135+P0141 codes. I ordered all 4 o2 sensors, and went with Bosch. Their site said #15703 for the pre's, and #13474 for the post's.
Sunlit I just wanna be sure they have it listed correctly for the post's as well. Does this jive w/you?
Also..... do I have to use the GM anti-seize w/the glass beads in it, or will a general high temp (1600deg.) anti-seize sold @ the local parts store do?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
I can jive with those numbers. New sensors will be lube coated already so don't touch the threads. After getting the old ones out use a thread chaser to clean out exhaust pipe holes. There are ones for sensor holes.
---------- Post added at 07:53 PM ---------- Previous post was at 07:52 PM ----------
Do you know which 02 sensor to use at the cat? I ned replace mine since my check engine lights on.
What specific code(s) do you have?
R
Ruddbow
replaced the sensor, whole new truck. She was a little stubborn at removal.....no codes or SES light. Thanks again for your help.
