AC Resistor Issue
RAWVORTEC
Lburg
Only my high fan switch was working, so I replaced the resistor for it. It worked!! Day after that, nothing. Still only the high works. Is it blowing the resistor somehow?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
try replacing the switch but that sounds odd. is there clogging debris blocking airflow pass resister coils keeping it cooled down?
RAWVORTEC
RAWVORTEC
Lburg
When I took the old one out, it looked clean. and nothing looked burnt or broken. So how do I get up in there? Is there a good youtube video?
SunlitComet
OBS Jedi-Do Good
not sure about you tube myself but if it looks clean on the resistor coils look elsewhere like the switch or connectors for block and switches on the system and look for signs of overheating.
qukon 95
it might be the blower motor using to much current in my dodge van i kept blowing my blower resister 4 times finally i replaced the original blower motor no problems anymore.
SunlitComet
OBS Jedi-Do Good
rotor shaft in the blower motor. non-serviceable unit to the end user. you just replace the motor. the commutator bars or windinds in a d.c. motor can short causing issues sometimes that may mimic your resistor burn-out issues. example of worn ones.
b18cls1
