Leveling kit and upper control arms
SpareParts
North Idaho
I assume that a 2in front leveling kit using spacers would be fine with stock upper control arms.
At what lift height would it be a good idea to install upper control arms for a lift?
I also assume with a 2in or more kit the front diff would need dropped to keep the axles more or less level being an AWD.
I want to install a spacer style leveling kit between 2 and 3 inches is the reason I'm asking.
I'll use the Belltech rear shock spacers so i can keep the air shocks.
I know how to make the rods for the height sensors longer and fine tune the suspension for the ride i want using the sensors so that's not a problem at all.
Trying to fine tune my options before i order stuff.
Thanks!
DennisWM
