I have a new to me 2005 Suburban LT 4x4 with Auto HVAC and rear air
The AC is blowing hot air.
1. Fuses and relay are all good and tested.
2. AC clutch isn't working.
3. I jumped the low pressure switch to see if the clutch engaged, it did not.
4. I put a set of gauges on the system...pressure was 0...so system is empty.
Should I put a vacuum on the system and see if there are any leaks before changing the clutch/compressor?
What would be the best plane of attack?
