AtomicHoe094
Atomichoe094
Accuspray air brush and supplies sollddd
SOLD
Heres my air brush, i used it once and you can tell when your good at something and when your not good at something..... im not good with this. lol I need a real spray gun not this little thing. I paid over 160 for it a year ago, they still sell around the same price. Ive included a bunch of other air brushes that are just in there for the hell of it, and an assload of lines. size varies from like 7feet to like 20feet.
Threw in some stencils and stickers of American flags that you peel and spray around em. couple small jars and stuff too..
The accuspray gun is pretty damn nice. it may or may not need a new needle, i dropped it just as i was taking some picture of it and of course it landed on the tip, but it might be alright. They still sell parts for it which is good.
looking for 75shipped for everything in the box to the lower 48states. thanks
Part #: ACC.06-200/3
Precise CNC Machining
CNC machining allows for consistent precision and control, yielding tight & detailed spray patterns, effective balance, concise adjustability & responsiveness.
Dual Action
Dual action allows for easier control over line width, paint opacity & range of value (important in gradients and blends
Lightweight
Lightweight brushes provide the artist more comfort and control over longer time frames.
Internal Mix
Internal mix feature allows for a wider range of effects from stippling & marbleizing to gradients and background coverage while producing finer detail and smaller lines.
Trigger Spring Adjustment
Trigger spring adjustment allows the artist to customize trigger tension for better control and personalized responsiveness.
Stainless Steel Needle / Nozzle & Solvent Resistant O-Rings
Stainless steel needles & nozzles with solvent resistant o-rings will withstand use with both water based and solvent based paints.
Self-Centering, Self-Sealing Fluid Tips
Self centering, self sealing needles add to the precision machining benefits of detail and control, adjustability and responsiveness.
Large Trigger Rocker and 1-Piece Trigger
Larger trigger rocker and 1-piece trigger allow for easier assembly.
Angular Gravity Cup Design
An angled gravity cup allows for better and more consistent fluid flow into the airbrush fluid chamber.
URL=http://img526.imageshack.us/i/img21980.jpg/]
[/URL]
SOLD
Dual Action
Lightweight
Internal Mix
