Adaptive Cruise Control
Eiran Rodriguez
I have a 2019 Tahoe Premier, when I press to activate the Cruise Control the Adaptive Cruise Control icon displays on the dash. When I try to set the speed I get a message on the dash "Adaptive Cruise Control Temporally Unavailable". The Cruise Control cancel button to the left doesn't turn this off neither does the break (not sure if that's a thing). It's only when I press the Cruise Control button to the right will it turn off. My issue is I want to change from the ACC to just regular Cruise Control but holding the cancel button will not switch it (what the manual said to do). When I bought the Tahoe it was lifted and has a Fab Fours Vengeance Bumper. I'm thinking there might have been an issue reconnecting the radar or sensor when this was replaced. I was unable to find the shop that did the install. Is there an easy work around to this? I tried to be as descriptive as possible. Any insight would be appreciated, thanks in advance.
E
Eiran Rodriguez
Any codes from the module?
Yes, Action Required - Front Radar Blocked - See Owners Manual and Information - Forward Collision System Unavailable. I'd like to add that the sensor that controls the seat vibration still works when I pull up to like the garage.
GMCChevy
Senior Member
Did you look underneath for the sensor? From your description it sounds like maybe that bumper is blocking it.
shootir
