Added Charging module to Constrained 2023 Ultimate
ninjaplumber
My 2023 Ultimate with sliding console came without the phone charger. If you have one of these and lift the rubber mat console and see a module that says "Not Functional" it is not that hard to install the fix. Maybe about an hours labor. Total cost for the 2 items about $150.
You first need to unbolt the passenger seat and slide backwards. Then remove the trim on that side. 20231216_080129.jpg
The module can be removed by reaching under the console, unplug the non functional unit and removing 4 screws. This pic is my cellphone looking up.
Install module #84974084.
You should also replace the rubber mat on top with the wireless charging warnings but not necessary. Part #84477079.
Hope this helps anyone interested. I could not find this information.
CDONNS
I wonder if anyone makes an upgraded module for this. The stock one, which I assume this is, just doesn't perform well in my opinion. I recently installed the Boost Auto one for the arm rest pocket and it is leagues better in terms of charge speed.
juantavarez127
