Adjustable Pedals Inop.
kc_g8s
New to me 06 Suburban LT. When I bought it, the pedals were all the way back (closest to the driver) and will not go forward. When I press the buttons, I hear a clicking on the back button and nothing on the forward. Any help appreciated.
Welcome to the forum Casey. Without a Tech-2 we won't know what the internal BCM codes are for it. You'll have to crawl underneath the dash and watch what happens when you try to move them. Probably a busted gear but not sure.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Welcome to the forum.
Like swathdiver said, will need to look to see if gear or track has a problem. The forward is silent because is already all the way back toward you. It sounds like the signal to go the other way is getting there, the click noise, but system is unable to respond. Might check and if you see no mechanical problems try pushing down on the pedals and might have to use some WD-40 on the track to help coax it.
HiHoeSilver
Away!
Chicago
Do a little search. Someone else (maybe even 2) had this just recently. Might have some insight.
raceguy13
