Aftermarket Performance Radiators????
Tozan
Overlander
Yavapai Arizona
Cold Case is the way to go. I had both, brand new in my garage. The Cold Case is what went in. In either case, it's not a drop in. The thicker core requires things like trimming back flanges on the fan shroud, adding sealing foam, etc.
Just make sure you put a restriction in the small hose that goes from the top to the radiator to the surge tank. The flow through this hose bypasses the thermostat, and is like having a half open thermostat all the time. Factory radiators have only a very small hole feeding that upper hose connection.
This pretty much sums it up it does need a restriction on that hose and with mine the Trans cooler line bung is not sealing so Cold Case sent me an exterior oil cooler. In the future I will re machine the bung and use the internal as well as the external they sent me.
My reasoning to run both is because I live in Arizona and in the summer when 4x4ing extra cooling is a good thing.
Safetypup
