Aftermarket wheels
I bought a set of XD Hoss2 for my yet undelivered 22 Tahoe z71. I purchased 20x9 with +18 offset. Are there any problems with this fitting without modification. I couldn’t get the factory +24 in this wheel.
What tires are you planning on running?
Original. Just wanted to change the wheels, not worried about stance. I had read on the thread where some wheels wouldn’t work with the brake calipers on the 21s. Just making sure these will work.
8D49EC74-E875-4277-8E44-3E2BCCB87D4A.pngWhen I added the details to discount tires configuration tool, it says these won’t fit. Any idea why?
m1949
LS364/450
MS Gulf
Has anyone had any luck finding aftermarket wheels that will definitively fit the 21's?
Everything I've come across stops at the 20s.
The bolt pattern will work and the offsets are good as well just not sure if the spokes will hit.
I heard the same thing on the 20 1500s but had no issues at all.
I'd hate to grab a tire and wheel set only to find out I'm screwed.
If bolt pattern, width, offset and bore diameter of the wheels you’re looking at are the same as the wheels on your ‘21, I can’t think of a reason why they won’t fit.
Thanks. I’m gonna stop sweating it. Not much I can do at this point anyway!
RobMuff
