Air/ Autoride
fishingwizard
So I did a 2" spacer lift kit front and rear on the burb and I need to adjust the rear airride sensors to make the shocks level when towing, as she sags 2-3" when hooked up to the boat because the sensor won't trip the compressor. I have read somewhere that there could be some aftermarket brackets for the sensors to raise them OR I have look at welding a 2" extension in the sensor arm by a buddy of mine.
What have y'all done to remedy this?
Thanks.
fishingwizard
fishingwizard
Thanks for the info and I will be ordering those longer sensor arms asap! I just used the Suncore spacer lift 2" that bolts on top of the coil over on the front and a 2" spacer that sits under rear coil spring. I used the 2" spacers on all four corners but I also went up two sizes on tires to 33s so the truck actually sits prob 3-4" taller than stock. I will grab some pictures tomorrow. I had to replace all of my shocks and used the Arnott shocks and compressor they were easy to install and also 1/4 of what the Chevy wanted to replace them.
xBoostx
