air bag height vs static drop
thor1125
orange county
so im installing air bags on my tahoe... i am doing BOA in rear with 1 inch cups , and some custom mounts where the stock front shocks are located... what would this setup be comparable to in a static drop(aired out)? like would it be lower than a 3/5(hopefully)
Max
Mile High
Denver
You'll need to run spindles up front and notch the back if you want it to really lay out otherwise it will sit about 4/7 aired out depending on the front suspension.
thor1125
thor1125
orange county
ya i plan on running spindles and lca after i install everything ... im working on getting the rear done first , then gonna look for the best deal on lcas and spindles and do the front ...
Tssonebay
