Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
thanks found it, so it lists as for 05, 06 only does anyone know why and can i make it fit an 03? as you can see the valance that it attaches to is the same for 00-06 so should work, right?
id imagine so... i think they might just list that because they came factory on some?? might be wrong.. ive seen a couple on the trucks, that older people were driving with no intentions for adding stuff like that to there vechile....
Yes it will fit. Like the guy above said it commonly came on 05 and 06 models. My Tahoe is and 04 and it fit just fine. There are only 2 mounting screws on each side and a lip that slides over the existing valance. Blizzard had a post up before that shows he added a few more mounting screws to hold it in place. I followed his example and did the same. Very easy to install and it stays in place with no issues after adding the extra support. Good luck.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
