my reading is off by 20 degrees F higher upon cold start up it's reading 78F-82f when is barely 57F outside
how is the accuracy on yours? it did drop to 73F after a few miles of driving but stayed there
cold start 20f higherThe air going into the motor can be considerably higher than the ambient temperature outside, especially if she's been idling or in traffic. Then I've also witnessed the air going into the motor a few degrees cooler than ambient at highway speeds too. Lots of variables at play.
i was checking mechanics data base about the IAT
parameters should be ± 10F
the response time is "very slow" as well.. considering it took a mile to go from 26C to 25C or about 1min and 30 seconds of air movement then worked its way down to 22C after the engine warmed up to 210f
also i was wondering if anyone can check their IAT on a cold start..
also BTW the temp on the mirror is correct 57F = 57 f outside (double checked on the phone to make sure it's correct)
thanksI'll check at first light.
that confirms it is faulty if mine is showing IAT 20 degrees higher on a cold [overnight off ]start...Truck facing the garage, no breeze through grill, low speed fans running as AC was on.
Cold Iron
ECT = 89
IAT = 77
AMB = 77
The IAT is part of the MAF correct?
