all coolant was drained before installing any parts, filled after.
Hot AC running. (blows room temp)
both heater hoses are hot and hard to the touch.
both top and bottom radiator hoses are cool untill the engine reaches 240+ then they swell and feel hot to the touch.
checked radiator flow by filling coolant from the top hose and watching it come out the bottom hose.
coolant ressiviour is bubbling almost like its purging air.
over flows when it gets past 240 F.
thermostat is rated at 187f
not sure whats keeping the coolant from making a full cycle here. please help super confused this is a 2006 chevy tahoe 2wd ff 5.3
either the thermostat is stuck or inserted backwards or pump is not working or perhaps heater hoses routed backwards
1st clue is cool radiator hoses
heater hose with y goes on forward pipe, heater hose no y goes on rear pipe
2 clue is heater only blowing luke warm which means coolant is not cycling
thermostat should be tested, take it out and put it in some boiling water, see what happens
correct thermostat position shown below
