air pressure?
highrollin113
Undercover
Edmonton, Alberta, Canada
i know from my days working at a tire shop to inflate tires to lbs recommended from gm, but im wondering what everyone else is running and why?
im at 35lbs because it says too in the door, any insight will be appreciated
thanks
KrautBurner
Bremerton, Wa
I run about 40lbs in mine,
I'll be running higher (probably about 60lbs) when I change out my tires to GoodYear Silent Armor Pro-Grades
andrew383
indiana
Easy way to check to see if the pressure your running is correct is to do the chalk test..
Take some white chalk,paint marker,something you can see on the tire and draw a line across the tread..Doing this on concrete/asphalt works best,but drive over the line just drawn on the tire and see where the tire contacts the ground..
If you still have marker on the outside of the tire then you have to much pressure,and if you have marker in the middle then to little pressure..
Hope this helps :)
