SteveC-VA
- Joined
- Sep 29, 2018
- Posts
- 6
- Reaction score
- 2
I am new to this forum but have been searching multiple forums for info on my issue. I am pretty handy and do most of my own vehicle maintenance, have a herd of 7 different vehicles, the 2007 Yukon XL Denali being the one in need of help. I noticed my highway ride had become bouncy and sort of floating so I suspected the air compressor had gone out again. I bought the truck in June of 15 and it had a very noisy compressor, I had to change it shortly after I bought it and it worked fine for a while, I noticed it had stopped working about 4 months ago. I ordered a new Arnot from RockAuto and put it on and still would not work. I started checking the fuses and connections and still cannot find the issue. I put 12v right to the compressor, old and new and they both turn on, with the unit installed,I get a single click at the compressor when I turn the key to the run position, same indication if I start the truck. I have removed and cleaned the ride level sensors on the rear and tried to take resistance readings on them but not sure what I should see between the pins on the sensor. I haven't been able to find much info on them and don't want to just change them out at 60-120 dollars each. I am not getting the 12v at the body side connector at the rear so I checked the relay under the hood and not seeing it there. I have checked all the fuses I know to check and they are good. I want to ask if anyone has a good schematic that I can download to use in tracing out the wiring to see where my voltage or control signals are being lost.
