Air Suspension and Air Horns?
PlazaEJ
Is it possible to tap into the air ride suspension system, to power air horns?
Or, would the compressor wear out too quickly, keeping an air tank filled?
EJ
yates ™
Resident Apple hater
Iowa
Factory system does not have a tank.
chip
Tampa
I have a tank, pressure switch and dual air horns that I just pulled out of mine (that I'd sell you) if you decided to try it. You'd probably need a separate compressor though. That's how I had mine setup.....and it was LOUD!
P
PlazaEJ
Thanks, Chip. I'll keep you in mind.
EJ
chip
Tampa
EJ
NP. If you do decide to go through with an air horn setup, let me know first (even if you don't want my stuff) because I've aquired quite a bit of knowledge on the subject. I can most likely help you a lot (I.E. avoiding common pit-falls, pressure switching, relay systems, wiring, etc.).
No matter how you decide to do it, I'll be more than happy to help in any way that I can.
OklahomaSideShow
