airbag code 31
northyukon
hoping someone can help with this 96 yukon i cannot get rid of airbag code 31 clock spring derm and arming sensor all replaced but no succes any ideas?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
woohoo, airbag code alright!
look at your arming sensor connector for damaged terminals and wires specifically the light green and yellow/black ones between the sensor and derm. you got the code because the sir system detected an open circuit on the "driver vlr 36" circuit(yellow/black) for more then 500msec. the light green wire is used to monitor it. while it was a good try to replacing arming sensor that only leaves those two wires and terminals as the likely cause. the diagnostic energy reserve module being a issue is highly rare and as for the clock spring, it had nothing to do with your issue. sorry.
N
northyukon
thanks i will be looking at that tommorow night and hopefully gets rid of the code for me
N
northyukon
it has been repaired it was the driver circuit the break was in the harness from the arming sensor up to the main harness 8" of wire some solder and heat skirnk tube it is repaired thanks for the help
blanchard7684
