Alignment issues after drop
2016YUKONSLT
So I lowered my truck with Norcals 2/4 drop kit and added the 24" Futures. I went through 1 set of tires due to the camber being off. I had the alignment done twice with the first set and we got it close to specs. I just had a new set of tires put on with an alignment and cannot get it within the manufactures specs. I don't want to continue wasting money on tires ever 15k miles due to the camber.
What can I do? Add a spring perch spacer to raise the front 1/2" and then get another alignment?
I have the spec sheet at home and will add it when I get home.
gat0r
DFW
i didnt have that issue. dealership did my alignment
curious,
who is doing the alignments you've had?
what did they say was issue keeping you from getting within spec?
is anything bent(suspension wise)?
2016YUKONSLT
2016YUKONSLT
I'm having my buddy, general manager, of one of the major automotive repair shops in the St. Louis market do it. Suspension isn't bent. He says he can't get it to go any further.
gat0r
DFW
which kit did you get?
you get the one w/ drop struts or the one w/ spindles?
if strut, didnt it come w/ a camber kit?
def. reach out to Tony
2016YUKONSLT
2016YUKONSLT
curious,
Did the dealer do the install?
2016YUKONSLT
2016YUKONSLT
If I bought the spindles, would it help with adjustment of camber? Will the spindles make it ride better?
KBones
Yes, drop spindles ride best and very easy to get back into alignment spec.
