all on dome??
JesusArTorres
Tulsa, OK
Hot side = positive side. Remove bulbs, turn on the dome and map lights and check with a test light. The bulbs are less than one amp, so any diode rated higher will work. You have to make sure you install the diodes in the proper direction. There will be an arrow on the diode body that points out flow direction.
Pardon my nagging...
So, assuming the indicated sides are positive, this is how I would set it up, right?
I want the current from the bulb that lights up to travel to the bulb that I WANT to light up. So arrows pointing towards the map/reading lights?
Rivieraracing
Sorry, just seeing all of this now! Exactly what he said! lol
If your not sure about what direction you need to install the diode, temp solder one on and see if it works, if not then resolder the other direction and you should be good to go!
JesusArTorres
Tulsa, OK
Thanks, I'll do that to make sure.
Stevenfigu23
