lamerem
- Joined
- Jul 6, 2015
- Posts
- 94
- Reaction score
- 24
105,000 miles on this tank, and it's time for a blood transfusion. I'm prepping to change the fluid in the transfer case, front differential and rear differential. So far I ordered the rear diff gasket (I know that I could reuse the old, but since it was available I went ahead for piece of mind), picked up 5 quarts of Mobil 1 75w90, and 2 quarts of ACDELCO Dexron VI full synthetic (10-9243). I also bought one of those fancy little hand pumps from the big box store to make my life easier.
I went through the manual and it said to use the fluid weights I got, except for the front end it said use 80w90. I contacted a friend of mine that is a service writer at the dealer and he said the tech told him 75w90, not 80w90. Any idea why they would contradict the manual? I live in Iowa with the cold harsh winters, that is the only thing I can think of is the thicker fluid might not work as well.
Anyway, the transmission is next and I might wait until I have everything and just do it all at once. I am planning to do the fluid swap through the lines at the radiator. I am not a fan of the flushes, I've had a bad experience and won't risk it again. I am planning to use the ACDELCO filter, and new gasket as well as the same ACDELCO Dexron VI as I am using in the transfer case.
Advice from others that have taken on these tasks? All I know is the dealer is looking to get rich, quoted $540 not including the transmission. They were also very much against dropping the pan, they said it was pointless as the filters were made to last a lifetime. Well, my definition of a lifetime, and theirs I believe to be different. If the parts are available on the open market, then someone, somewhere thinks the need to be serviced. Besides, its only like 13 bolts and the pan is off, BLAH.
Lastly, someone posted on here somewhere (which I can't find now) that you should change the pressure sensor/switch/pump while the pan is off? Anyone know anything about this?
