Already changed the mode door....
treehan77
TYF Fiend
Crestview, FL
Good luck! Mine still gets stuck on one mode every once in a while but always fixes itself the next start lol. I had the evap code, ended up dropping the tank because the all the lines were packed with charcoal pellets all the way up to the purge lol.
A
ARogg619
Appreciate all the advice fellas! Forums are the best, most of the time lol. Im leaving for North Carolina tomorrow morning but leaving the truck home this time. When I get back ( next Saturday ) and find a day, im gonna try to redo the install of the mode door, redo the relearn and check everything 1000x and ill update you guys with results.
BobBilly
No Don't do that You just need to follow the reprogram proceedure. As Follows: !. Turn on your Key and be sure to push the Auto Button on the AC Controls. Turn the key off.
2. Open your Hood and on the Drivers Side, find the Fuse Box right next to the Battery. Look for the 10 amp Fuse for AVAC ECAS. wait for 60 seconds.
3. Start the engine and do not touch the AC/Heater controls. Allow the Doors to recalibrate for 120 Seconds.
4. Turn off for 10 to 30 seconds.
5. Restart your engine, and verify absolute cold setting and front output, on both sides then turn to the floor, verify. Turn on your defroster and verify air flowing at the windshield. Then turn on the hot temperature and verify the warm temp at various locations.
With all functions confirmed, You are done and ENJOY.
If anything does not work as planned, repeat again carefully.
Best Regards
Bob Downes
P S !! Anytime you loose power or replace a component, you will need to do this again. Just keep it in your Glove Box.
Fless
Super Moderator
Elev 5,280
Best Regards
Bob Downes
Weird. What does looking for the AVAC ECAS fuse do besides seeing if there is one?
markzabrycki
