Always get the service suspension message in my display
DJPoertsch
DJPoertsch
Hello everybody. I would like to give you a little update regarding my error with the Stability Track Control error message.
I installed an LPG system in my Tahoe because of the fuel costs in Germany.
We have now checked the system and the error was due to the fact that the engine was set too lean when the engine was run on LPG and after accelerating to the partial load range the LPG air mixture was set too lean. The second problem was that I had installed cheap oxygen sensors in 2019 that were defective. I have now installed originals and readjusted the LPG system on a test bench. I haven't had this error since then.
So only my Suspension service message would come on every time I will start my Tahoe. I try to figure out what else it could be. Fuse all out and still the message come on.
ezmoney1981
