Amateur install.
maddogoif
San Antonio, TX
Hello everyone. I'm fairly new but I've already done the introduction. I recently bought an 05 Tahoe with an alpine INA-W900 touch screen nav/media player already installed. The problem is it seems that the previous owner installed it themselves. Many of the steering wheel console buttons are reversed or not working at all. Also the buttons sometimes decide they don't want to work at all. Anyone have any ideas what I should look for to fix this? A shop would charge 200 just to map the wiring and diagnostic.
Sent from my HTCONE using Tapatalk
yates ™
Resident Apple hater
Iowa
There is a module wired to the radio that controls the steering wheel controls, it is either faulty or wired incorrectly.
M
maddogoif
San Antonio, TX
Thanks. Where would I find this module and where would I find the propper wiring.
blaqout
King Yukon
Indianapolis
Some of the steering wheel modules require programming. You have to hold a button on the module while pressing the remote button on the steering wheel. There are a couple of types. I have used the PAC SWI-RC
jdpber
GOLD MEMBER
The America
It is not hard.
Set parking brake.
Turn ignition
Put in 1
Tilt wheel all way down
Pop dash off starting top left.
Then you have 4 1/4" screw but heads. Boom. Takes maybe 1.5min if your slow. I can have these radios out in a hot 20seconds with electric rut driver. It is nothing to it.
M
maddogoif
San Antonio, TX
Here is what I'm looking at after taking out the frame. Seems odd that there's weld marks on the top right. Doesn't seem I can remove the radio separately.
Thanks for the help so far. I'll update how it pans out.
blaqout
King Yukon
Indianapolis
What's holding the radio in? Did they just jam it up in there? Normally there is an install kit that mounts the radio to the "radio cage" You should be able to slide it out with some elbow grease.
M
maddogoif
San Antonio, TX
I tug and pull on it so far and it tries to pull the AC consol along with it. Haven't loosened anything up yet because I have a feeling somebody had made my job slightly more difficult for me.
