Vincesrg03
Thanks for the info. I will probably tackle the job this weekend if the weather gets better here in chicago. I also read online that you should put in a relay to turn on the amp. That is use the remote wire off the headunit, and a relay to power it on. That way you get no return voltage to the headunit and ruin it. Has anybody done this, or is it okay just to run it off the remote wire. I haven't wired an amp in a long time and wanna make sure i do it right. Once again thanks for all the info. This forum is very helpful!!!!
