Amplifier 2022 Yukon
aph7649
Can anyone help with what is required to replace the amplifier in a 2022 GMC Yukon AT4? Our sound will go out intermittently, sometimes for extended periods, and replacing the factory amp is the dealer's best suggestion.
Where is the amp located? I haven't been able to find a clear answer online.
Is it reasonably easy to get to and replace?
P.S. Hopefully this isn't a repeat post - I think I accidentally deleted my original thread.
iamlegion
Hard to answer without knowing which system you have but it should be in the drivers side rear inside the big wheel wheel liner. Crutchfield has a guide or you could use the JL audio stealthbox install guide.
Garage2010
