Freedom Motorsports
- Joined
- Jul 16, 2011
- Posts
- 933
- Reaction score
- 20
AMSOIL Formula 4-Stroke Power Sports Synthetic Motor Oil (AFF)
Post Below Or Contact Us For More Information
CLICK HERE To Place Your Order TODAY!
Package sizes include:
1-Quart Bottle
1-Quart Bottles (case of 12)
30-Gallon Drum
55-Gallon Drum
AMSOIL Formula 4-Stroke Power Sports Synthetic Motor Oil is specially formulated for ATVs, UTVs, snowmobiles and other powersports applications. Its broad viscosity range and wax-free formulation make it excellent for use in both hot and cold temperature extremes.
PRODUCT DESCRIPTION
AMSOIL Formula 4-Stroke Power Sports Synthetic Motor Oil is specially formulated for ATVs, UTVs, snowmobiles and other powersports applications. Its broad viscosity range and wax-free formulation make it excellent for use in both hot and cold temperature extremes. As an SAE 40-weight motor oil, AMSOIL Formula 4-Stroke Power Sports Oil provides outstanding protection for hot-operating engines, while its 0W rating and -60°F pour point ensure easy cranking, excellent cold-weather starting and quick post-startup protection. Formula 4-Stroke Power Sports Oil is an extreme-temperature lubricant that provides outstanding performance in high-performance, recreational or work/utility engines.
Resists Heat and Thermal Breakdown
AMSOIL engineered Formula 4-Stroke® Power Sports Synthetic Motor Oil to withstand the high temperatures of recreational engines. It effectively resists oxidation and oil vaporization to help prevent carbon/varnish formation, control oil consumption and minimize exhaust emissions. It also controls oil thickening, promoting improved fuel economy, and it helps keep engines clean for peak operating efficiency.
Excellent For Transmissions
AMSOIL Formula 4-Stroke® Power Sports Oil is wet clutch compatible and contains no friction modifiers, making it ideal for both two- and four-stroke ATV transmissions. The friction modifier-free formulation is designed to prevent clutch slippage, helping deliver maximum torque and power to the wheels – a critical feature for towing or high-horsepower engines. It meets the frictional requirements of JASO MA/MA2 and ISO-L-EMA2.
Superior Wear Protection
AMSOIL Formula 4-Stroke® Power Sports Oil is formulated with high levels of anti-wear additives that provide excellent protection for pistons, bearings and gears in transmission containing units. Its shear stable, SAE 40 viscosity delivers a thick lubricating film for an extra margin of protection in hard-working engines.
Anti-Foam
Churning occurs in high-RPM engines that can cause oil to foam, depleting its lubricating abilities and increasing heat and wear. AMSOIL Formula 4-Stroke® Power Sports Synthetic Motor Oil controls foam, promoting cooler engine operation and reduced wear.
Special Additives
AMSOIL Formula 4-Stroke® Power Sports Synthetic Motor Oil contains robust dispersant/detergent additives that effectively neutralize the high levels of acids and combustion by-products prone to small engines. It is anti-rust fortified for superior rust prevention, which is especially important in seasonally or infrequently used power sports equipment.
Applications and Recommendations
AMSOIL Formula 4-Stroke Power Sports Synthetic Motor Oil is recommended for four-stroke engines. It is also recommended for transmissions on two- or four-stroke applications. It is an all-climate/all-season oil that replaces 0W-30, 0W-40, 5W-30, 10W-30 and 10W-40 oils for ATVs, UTVs, snowmobiles and other powersports equipment. Also recommended as a replacement for Polaris Synthetic PS-4 Plus and Arctic Cat Synthetic ACX. Manufacturers include Polaris®, Honda®, Yamaha®, Ski-Doo®, Can-Am® (Bombardier®), Suzuki®, Kawasaki® and Arctic Cat®.
• API SL/CF, SJ, SH, SG
• JASO MA/MA2
• ISO-L-EMA2
Compatibility
AMSOIL Formula 4-Stroke® Power Sports Synthetic Motor Oil is compatible with conventional and synthetic motor oils. Mixing AMSOIL motor oils with other oils, however, will shorten the oil's life expectancy and reduce its performance benefits. AMSOIL does not support extended drain intervals where oils have been mixed.
Aftermarket oil additives are not recommended for use with AMSOIL motor oils.
Service Life
Follow the equipment manufacturer’s recommended drain intervals.
Health & Safety
This product is not expected to cause health concerns when used for the intended application and according to the recommendations in the Material Safety Data Sheet (MSDS). An MSDS is available upon request at 715-392-7101 or on the AMSOIL Website. Keep Out of Reach of Children. Don’t pollute. Return used oil to collection centers.
TYPICAL TECHNICAL PROPERTIESAMSOIL FORMULA 4-STROKE® POWER SPORTS SYNTHETIC MOTOR OIL SAE 0W-40 (AFF)
Kinematic Viscosity @ 100°C, cSt (ASTM D-445) 14.7
Kinematic Viscosity @ 40°C, cSt (ASTM D-445) 83.7
Viscosity Index (ASTM D-2270) 184
CCS Viscosity, cP @ (-35°C) (ASTM D-5293) 6139
Flash Point °C (°F) (ASTM D-92) 226 (439)
Pour Point °C (°F) (ASTM D-97) -51 (-60)
Noack Volatility, % weight loss (g/100g) (ASTM D-5800) 7.3%
Four Ball Wear Test
(ASTM D-4172B: 40 kg, 75°C, 1200 rpm, 1 hour), Scar, mm 0.35
Total Base Number 10.5
