AMSOIL OE 5W-30 Synthetic Motor Oil (OEF)
Status
Not open for further replies.
Freedom Motorsports
CLICK HERE For Pricing & Ordering Information
Package sizes include:
1-Quart Bottle
1-Quart Bottles (case of 12)
30-Gallon Drum
55-Gallon Drum
OE 5W-30 Synthetic Motor Oil (OEF) is Formulated for Excellent Engine Protection and Performance
AMSOIL, the leader in automotive synthetic lubrication, produced the world’s first API-qualified synthetic motor oil in 1972. Trust the extensive experience of AMSOIL, The First in Synthetics®, to do the best job protecting your engine.
AMSOIL OE Synthetic Motor Oils help provide better wear control, high- and low-temperature protection and increased fuel economy compared to conventional oils. The oil drain interval recommendations for many of today’s vehicles extend well beyond the traditional 3,000-mile interval, some up to 12,000 miles with electronic oil monitoring systems. AMSOIL OE Oils provide excellent protection and performance for the entire length of the original equipment manufacturer’s recommended drain interval.
Improve Fuel Economy
Formulated with friction modifiers, AMSOIL OE Synthetic Motor Oils are fuel-efficient oils that reduce friction-related energy loss. They provide better fuel economy compared to conventional, non-fuel-efficient motor oils.
Maintain Low Emissions
AMSOIL OE Synthetic Motor Oils are friendly toward modern emissions control systems, promoting proper operation of catalytic converters for optimum service life and low exhaust emissions.
Protects in All Temperatures
AMSOIL OE Synthetic Motor Oils are multi-viscosity formulations. They resist the effects of thermal breakdown, including evaporation and viscosity loss, while remaining fluid in cold temperatures for easier cold starts and fast start-up circulation.
Keep Engines Clean
Fortified with high levels of detergent and dispersant additives, AMSOIL OE Synthetic Motor Oils are engineered to resist sludge and carbon deposits better than conventional oils. They promote clean operation for longer-lasting, better-running engines.
Bid Appropriate
AMSOIL OE Synthetic Motor Oils fulfill the requirements of most public and private purchasing bids. They are cost-effective, making them ideal where synthetic motor oil is specified.
APPLICATIONS
AMSOIL OE Synthetic Motor Oils are excellent for use in all types of gasoline-fueled vehicles. They are recommended for all domestic and foreign vehicles requiring any of the listed performance specifications:
5W-30 (OEF)
API SN (Resource Conserving), SM...
ILSAC GF-5, GF-4...
Ford WSS-M2C946-A, WSS-M2C929-A
Chrysler MS-6395
GM dexos1TM (supersedes LL-A-025, 6094M and 4718M)
Fortified with detergents that exceed dexos1™ sulfated ash specifications.
COMPATIBILITY
AMSOIL OE Synthetic Motor Oils are compatible with conventional and other synthetic motor oils. Mixing AMSOIL OE Synthetic Motor Oils with other oils, however, will shorten the oil life expectancy and reduce the performance benefits. Aftermarket oil additives are not recommended for use with AMSOIL OE Synthetic Motor Oils.
SERVICE LIFE
In gasoline-fueled vehicles, AMSOIL OE Synthetic Motor Oils are recommended for the intervals stated by the vehicle manufacturer or indicated by the oil life monitoring system. Change oil filter at every oil change.
HEALTH & SAFETY
This product is not expected to cause health concerns when used for the intended application and according to the recommendations in the Material Safety Data Sheet (MSDS). MSDS’s are available upon request at 715-392- 7101 or on the AMSOIL Website. Keep Out of Reach of Children. Don’t pollute. Return used oil to collection centers.
For AMSOIL warranty information, click here.
TYPICAL TECHNICAL PROPERTIES
AMSOIL OE 5W-30 SYNTHETIC MOTOR OIL
Kinematic Viscosity @ 100°C, cSt (ASTM D-445)10.8
Kinematic Viscosity @ 40°C, cSt (ASTM D-445)64.3
Viscosity Index (ASTM D-2270)160
CCS Viscosity, cP @ (°C) (ASTM D-5293)5570 (-30)
Flash Point °C (°F) (ASTM D-92)226 (439)
Fire Point °C (°F) (ASTM D-92)240 (464)
Pour Point °C (°F) (ASTM D-97)-43 (-45)
Noack Volatility, % weight loss (g/100g) (ASTM D-5800)10.6
High Temperature/High Shear Viscosity
@ 150°C and 1.0 X 10.6 s-1, cP (ASTM D-5481)
3.3
Four Ball Wear Test @ 40 kgf, 75°C,
1200 rpm, 1 hour, scar diameter, mm (ASTM D-4172)
0.45
Total Base Number (ASTM D-2896)7.9
AMSOIL Preferred Customers SAVE up To 25-30%
AMSOIL Dealer, Commercial & Retail Account Opportunities
Contact Us For More Information Or If You Have Questions Now...
originally posted here: http://www.syntheticmotorsports.org...e-5w-30-synthetic-motor-oil-oef.html#post3897
Status
06Tonka
