Another 4WD Question
mudslinger96
Texas
Hey Guys I'm Kind Of In A Bad Situation Right Now. It's Been Awhile That My4WD Hasn't Been Working Because Of A Bad Actuator Well I Finally Replaced It And Went To Try It Out And No 4WD. So I Checked Everything My TC Is Going Into 4WD And My Front Actuator.Is Engaging But My Front Tires Won't Spin. Both The Front And Rear Driveshafts Spin While Jacked Up While In 4WD But The Front Tires Do Not Spin. Can Someone Please Tell Me What May Be Wrong With It. My 4WD Was Working Before The Actuator Messed Up.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
You have likely broken # 14 the shift fork or the axle engagement collar that is moved by it.
mudslinger96
mudslinger96
Texas
Do you think I need to disassemble the whole thing to see it or just remove the part where the actuator is at
Rfunes
