Another 99 Yukon Gauge and tranny thread
GIMike
I have a 1999 Yukon with almost the exact same issues as in the other thread. I'll try to describe my problem in more detail. When I turn the ignition on, the "gear indicator" light (which tells you if you're in park, drive, etc), will more often than not be very weak or be almost flashing. If I wait awhile with the key on without starting, it may get brighter and become solid, it may not. If it is bright and solid when I start the car, and it stays solid, I will have full first gear and OD and all my gauges will work properly. If it's still flashing or dim, I may or may not having gauges, but I will not have full 1st or OD. Another odd thing (this may point to the 1-2 shift solenoid), is that if I shift from D to 3, the gear indicator light will stay normal. If I shift from 3 - 2, the light goes out and my gauges will quit working. Oddly, if I put the shifter into 1st, it will go into first, but when I shift into 2nd, it will shift pretty hard (I'm not doing this with the RPMs too high by any means, I know how to drive a stick), so I don't do that very often.
I've been dealing with this for the past couple of years, and it hasn't really been an issue. It's just been really slow to take off and uses more gas, but it never got worse or left me stranded. Was pretty dependable. Until recently. I move and hauled one of those little covered uhaul trailers. I don't know if the not having full first gear caused my throttle position sensor to go out due to having so much more load than normal, but it runs like crap now. It shakes horribly when idling and barely moves when put in gear. This happened towards the end of my move when hauling the trailer, it just kept losing power until it got to the point where it is now. It shakes so bad that I'm scared to drive it anywhere. I've been riding my motorcycle to work every day and it's getting cold and so I'm about to give up. If I can't figure this out cheap, and quick, and soon, I'm just going to put an ad in craigslist to see if anybody wants to trade me for something that runs and drives. I'd take an 82 ****** if it ran better than my Yukon. Due to a recent divorce and child support, I'm only getting about $200/week at my $13/hour job, so I can't afford to go out and buy various parts for $100 a piece until I fix it. I knows the parts that will fix it aren't cheap, but I can't afford a lot of guessing games. The people from the auto parts stores of course want me to replace every sensor and fuse they can get out of me. I'm not convinced this is the answer. Any help would be greatly appreciated, as I've had this truck for almost 10 years and am not ready to give up on it, as it's only just now letting me down.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
GI, if you want to test and be sure it is the ignition switch contact, get a volt meter and probe fuse #20 for voltage. If when the problem is occurring the voltage is all over the place while voltage is stable say at the the large orange wires at steering column connector under the dash you can assume your switch is probably dead.
While there are maybe a minor change in wire color. The diagrams below should help trace out where along the #20 fused circuit is failing you.
Print these out as the pictures will change soon.
Power Distribution Diagrams
Power Distribution
Notes
161922840
Power Distribution
Notes
62392092
Power Distribution (Cont)
Notes
62392093
Power Distribution (A, B & C Cont)
Notes
62392094
Power Distribution (F, G, H & J Cont)
G
GIMike
Well, I'm in need of a car asap. My fiancee just lost hers tonight, and the only car we have left is my busted Yukon. I've got some family that have shops, and they have some cheap cars they'll sell me. I figure if they'll give me a decent price on something that runs, I'll sign the title to my Yukon over to them. Unless anybody who lives in Oklahoma wants to give me a price on it by tomorrow, then I'm afraid it'll be going away. Sorry for bugging you guys about a truck I can't fix. :(
Donnie Yukonie
Yates Caretaker
I would say fix it. I see that being cheaper than a car
Sent from my DROIDX using Tapatalk
Stevemo70
