Another AC Problem
gmurphy
I replaced my AC compressor and now the compressor will not kick on. I jumped it to the battery and it comes on. The AC blows on the floorwhen the AC button is depressed. If i turn the AC off it will blow out of the dash. It onlyu blows hot. Is my AC head bad?
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
I would also check the connector and low pressure cycling switch that I know you replaced when you did the accumulator as recommended. Should have also replaced the expansion valve and flushed the system. If you did not then shame shame.
patniven
