MooseKuckle
Hopefully someone has come across this: replaced brake pads and started noticing a light grinding when cab is quiet, 15-20mph coasting. Had the braking system inspected and was told the rear calipers were sticking. Instead of a rebuild kit I bought new HD calipers for replacement. Definitely brakes better now but the noise is still there. Could this be a bad front wheel bearing? It doesn't fit the description of the sound I've read. Another thing I noticed was after I replaced the front rotors they are becoming a little discolored from excessive heat. Waiting to see if the replaced rear calipers fix that problem and will update after some driving.
Any suggestions would be appreciated.
