Another headlight question here
Yukie dookie
I run spec D projectors uses h1 bulb and the quality I think imo is Crap....I'm bout over the halo led thing it jus doesn't seem to be an oem quality kind out there, my question is can I run the Denali projectors and add hid if I choose too and cause I didn't install these can someone tell me how to uninstall? They are hookd up to my parking lights if anyone knows their way around these thanks in advance....
TheAutumnWind
Denali projectors work pretty well with HID's. Not as good as a true HID retrofit, but they wont blind anyone if properly aligned and work better than the spec D stuff...
Get a quality HID setup from TRS
Y
Yukie dookie
Will any year Denali fit my Slt????
I'd like new if they are affordable,,,,any part numbers out there???
YukonXL04
The Riverboat
Arlington, TX
For the same price as new depo projectors... you can do a true retrofit...
You buy factory looking yukon lights with a clear lens. They are on ebay. Then buy some projectors from the clearance area at TRS. And tada real hid projectors in a stock housing.
Or you can skimp out and just buy DEPO brand denali projector headlights and slap some HIDs in them.
You can find the depo branded ones on ebay and amazon. Also on rock auto I think.
I would definitely do a retrofit though because the light output is waaaaay better. I have some depo projectors laying around, and did some comparing cause I was gonna put them on my golf cart. But I'll buy generic h1 projectors before I use these depos...
Y
Yukie dookie
I'd really like to do a retro fit but not too comfortable with doin it I'd hate to fail at it lol....then end up costing me more money...
---------- Post added at 10:19 PM ---------- Previous post was at 10:16 PM ----------
Is dorman brand comparable to depo????
YukonXL04
The Riverboat
Arlington, TX
To my knowledge, the only acceptable aftermarket denali projectors are the depo brand
Y
Yukie dookie
What's the best way to modify the harness to fit 9005 Denali housing should I solder new 9005 harness to fit light housing or??????
YukonXL04
The Riverboat
Arlington, TX
If your gonna put HIDs in then I wouldnt bother. Just get the relay harness with a 9006 plug, and then from ballast to bulb will be amp connectors with a 9005 HID bulb.
Y
Yukie dookie
I thought I had to modify my Slt plug but I guess the depo light is a plug and play no modifying correct???? Not lookin to do hid at least not now....
YukonXL04
The Riverboat
Arlington, TX
Well your stock headlight plug is a 9006, and the denali bulb is a 9005. So just buy a 9006-9005 adapter and be done. So you aren't cutting and splicing things. Easier to revert back to stock that way
rsyoder96
