Another oil pressure saga!
JKaechler
JKaechler
Put two more quarts into the motor and then check the pressure idling or driving around. If the pressure stays up, it's the o-ring. If it does not, the problem is elsewhere.
i read somewhere that this test needs to be done on a slope? and its bad to leave the over capacity in there for a long time?
1 quart with a sloped drive. Some guys say to add 2 quarts and use a sloped drive to check it. I learned on these forums that 2 quarts and a flat driveway is good enough.
You can drive around with it, a guy on here who was down on his luck drove his truck like that for two years until he could make the repair.
JKaechler
JKaechler
that is excellent information! I will conduct that test in the next few days. many thanks!
Tom-M
On my 2011 Tahoe with roughly 200k on it, I have the classic symptom of low oil pressure after it warms up. I will be swapping the sensor and deleting the little screen this weekend, but i dont hold out much hope that will resolve it.
So, assuming i am moving onto the o-ring on the pickup tube: Do I need to plan to replace the oil pump while i have the pan off? Its a 4x4, so pan removal looks like it will be a pain, but not the end of the world.
if so, high volume pump? or standard pump? I dont race or anything, i bet the engine will hardly ever see more than 3500rpm.
I had a 2008 Trail Blazer with the 5.3L in it. When it got warm, the oil pressure would drop to zero and a warning would come up on the DIC. I changed the sending unit and it still did it. When I took the new unit back out a second time, I dropped the screen and it was never to be seen again. I put the old sending unit back in and the oil pressure read correctly from that point on until I sold the vehicle.
Geotrash
Dave
Richmond, VA
Correct. It's not usually the sender itself that's the culprit for low oil pressure readings - it's the screen.
j91z28d1
but if you have the afm running, I wouldn't leave it out. replace or clean.
all that stuff that clogged your screen would be pumped thru the inside of your lifters, which have very tight tolerances. once a lifter sticks you're pulling a head at best.
if that's clogged it probably means you have sludge in your engine. mine was clean at 135k when the sensor when out(failed maxed out), but the inside of the engine is spotless. I'd love to know what the previous owner did for maintenance. what I saw on car fax was nothing special.
Geotrash
Dave
Richmond, VA
Good clarification. I didn’t mean to suggest leaving it out - only that the screen itself is usually the source of the problem and needs to be either thoroughly cleaned or replaced.
j91z28d1
yeah, I only said that because the post above said he left it out till it was sold. I don't know if a tb has afm? I guess it would since it had the screen.
JKaechler
JKaechler
An update on this saga, and some background.
I bought this Tahoe 6 weeks ago, and its two issues were the low oil pressure and the tranny was nearly toast. straight to a full trans rebuilt it went. (it was in the budget from the beginning)
This week i got it back from the tranny shop, and immediately changed the oil. on the way home it read about 25PSI when driving around 1500 rpm.
after the oil change it reads about 35psi at idle, and hovers right at 40psi when driving. that is true when cold and also when hot.
I put in 1qt of Lucas oil stabilizer, and the rest is normal quaker state high mileage. I did not overfill as was suggested earlier. I wanted to try it out with a normal amount.
the oil that came out did not seem to be anything horrible. maybe a bit old but fairly normal.
Dustin Jackson
Your oil pressure levels after the oil change are good, no need for additives or stabilizers in the oil.
I just changed my oil and with this oil + filter combination my oil pressure falls below the 20 mark at hot idle but nothing to sweat about, motor still sounds smooth. Cheap walmart brand dexos oil...
nortega1989
