Im having a bit of an issue with an Antifreeze leak. The issue is I cannot find where it's coming from. I have the 6.0 (Vortec 6000) and it only occurs when I shut the truck off and leave it for a while. It's leaking from the passengers side. I had the mechanic perform the pressure test thinking it could be a hose but to no luck. Left the pressurizer on there for about 10 minutes with NO leak, or drip ANYWHERE. I was told that it may be the exhaust manifold gasket bc "There's a crossover that returns the antifreeze to the reservoir" I was next told to let it get worse to see exactly what the problem is. Im not overheating or anything. I have to refill the reservoir about every week and a half to two weeks. Anybody able to help me out? I really would like to correct the problem ASAP. Any help will be MUCH appreciated. Thank You
