any idea on replacement door panel?
backwaterdogs
HI everyone...I'm in need of the front drivers door panel for 98 tahoe...gray.
I know these things aren't suppose to get damaged beyond use, but I've managed to do so.
Anyone aware of a good source? A couple on ebay, but hard to find right color, side, etc.
thanks!
kcb37
I would be visiting the junkyards around you.
little hard to find sometimes, gray probably going to be real hard.
New
www.lmctruck.com
www.classicindustries.com
Pickup 1/2 ton to 1 ton, Suburban, Tahoe will all work.
Pretty sure GMC is the same door panel too.
_Dylan_
STAY FROSTY
go to a junkyard, u-pull, auto savage...whatever they call them around you.
gray is easy to find.
B
backwaterdogs
thanks!
got lucky and found most of what I need at a junk yard.
the panel didn't have the switch bezel, though...picked that up off ebay.
in case anyone is interested, I got a door panel at a u-pull junk yard for $20...most panels on ebay are around $100.
dirt
