Anybody have a 6 inch with 33's?
TAHOEZ71BOY
Texas
I just recently lifted my Tahoe with a BDS 6 inch lift and was told that i couldn't put on bigger than 33's, so does anyone have any pictures of a Tahoe with a 6 inch lift and 33's?
Gzes
the drifting 2dr
Wichita tx
You can fit 35s. 33s look a lil sma on a 6in lift imo. 35s might need small trimming but will fit. Hell 3in fits 35s tucked in with trimming
Gzes
the drifting 2dr
Wichita tx
Trimming will still work. Offset is your problem. Imo i would sell the rims and get some with better offset
T
TAHOEZ71BOY
Texas
The offset is fine, it sticks out about 2 inches from the fenders, the width of the rim is what is killing me, i need atleast an 8 inch wide to fit 315/75/16's
fast_jason
What size rims are you running now? 16 x what? I ran 35x14.50x15's on my 98 2door with a RCD lift. I had to trim the front plastic a little, but they didn't rub after that.
T
TAHOEZ71BOY
Texas
They are 16x7's apparently I can't fit above 285's because its not wide enough
fast_jason
I would get new wheels that are 16x8 and then go with a 35x12.50 or similar. You should be able to find a decent set on Craigslist to get you going or if you have the funds already set aside then get some new stuff.
arveetek
Granby, Missouri
I just put on 33's with no lift! 285/75R16 tires on 16x8 rims with 4.5" backspacing. Fits no problem.
Casey
Donnie Yukonie
Yates Caretaker
33s wouldn't look to bad But as stated With 6 inches 35s are a must
Thumper68
