anybody have a clifford alarm setup?
OmarR
Indianapolis, IN
I just went out and checked it out, I can control if my unlock options through the DIC (just seems wrong everytime I type that word!!:boxed: :)), either just the drivers door, all doors or none!! If I remember right for the rigs that don't have DIC their rigs can still get programmed to do the same, can't remember if the owners manual says how to or if the dealer has to do it!
All that is true, but it's all unlock functions when you take the truck out of park, exit the key from the ignition, etc.
It's not for the keyless entry.
Max
Mile High
Denver
My 50.5x opens them all using the gm module. Sounds like a bad ground or the goofy dic issue.
Rivieraracing
Oh, figured it would control the keyless entry as well, I stand corrected!!
OmarR
Indianapolis, IN
On the 03-06 trucks, there's only 2 ways to do unlock all with an aftermarket remote:
1. Double pulse from the aftermarket alarm (Clifford, Dei, etc).
2. Programming your door lock interface (such as GMDL-BP) to unlock all.
So for the OP, it will depend on which clifford alarm he as, as not all of them have the double pulse output, or which GM door lock interface he is using, IF he is using one at all, since a 5-wire relay setup will also work.
Nothing on the DIC menu or the truck's factory options will help him.
Rivieraracing
Dang brotha, you got alot of knowledge about this subject for sure!! Help this guy out with his problem if you could, if I could I would!!:)
brndns_hoe
brndns_hoe
Plano, TX
sorry guys, i've been out all day, thanks for the responses, tomorrow i will see which model i have, and look in the book, maybe it clarifies if mine has the double pulse thing...as far as the door interface lock, how would i know if i have one? and can i program it myself or will i have to take it back to where i got it installed?
juantavarez127
