Anybody installed a Denali bumper??
01yukon
Lynchburg, Va
I have an 01 Yukon and I wanted to install a Denali front bumper. Does anbody know how involved this is?? Will it fit over the stock bumper with the valence removed?? Please help!!!
Badluck
SE WI
No. Different body lines. The Yukon grill dips in the middle of the bumper. The Denali grill/bumper is flat all the way across.
tast101
Colton, CA
That's just the bumper cover. That's the first piece on the list below. You need a lot more than that.
You will need....
Denali front end conversion parts
12479754 - Bumper cover
15046662 - Filler between grill and bumper - LH
15046666 - Filler between grill and bumper - RH
15199554- Parking lamp – LH
15199555 - Parking lamp – RH
19130789 - GMC Denali Grill superceded
15218077 - Headlight – LH
15218078 - Headlight – RH
14093088 - Retainers (7 needed)
15149708 - Retainers (12 needed)
15153490 - Insert
15060470 - Impact bar
16531085 - Fog lamp Assembly – LH
16531086 - Fog lamp Assembly – RH
15059859 - License plate bracket
88937235 – bumper filler
15706323 - emblem
88944418 – Fender right
88944417 – fender left
12477699 - Hood
You don't need everything, but I would say everything in bold, minus what can be re-used
01yukon
01yukon
Lynchburg, Va
Looks like I would be better off just buying a Street Scene bumper or something like that.
carcrz
Georgia
hey 01 yukon... the denali bumper will fit on your truck. i have done it to my, with just a bit of modification to your bumper but to make it look good you will have to replace your grill to a denali one thats about a 800 dollar swap, but if you don't do that i can sell you a street scene bumper cover, clear corners, let me know if you are interested
Badluck
SE WI
post a pic of the clear corners....i might be interested
carcrz
Georgia
[/IMG]
here you go
Ejwr
