Anyone else’s washer fluid make this noise?
iboughtatahoe23
iboughtatahoe23
Ok so I guess I’m not allowed to upload video links anymore… Or any media for that matter so I guess I’ll just explain the noise the best I can; it’s just like a buzzing noise. I can hear outside the vehicle when I engage the washer fluid. Like a “ZZZZZZZZ” higher pitched.
Matthew Jeschke
Sahuarita, Arizona
I don't know that mine does... Hard to say, are any of the lines bent or creased? They probably run along the driver side fender just below where the hood comes down, tucked in under the lip of the fender. Next, there's a little pump in the revivor. Have somebody listen there as you run it. Maybe the motor has something pump with it.
That said, only thing I've ever worried about is that the fluid comes out on my windshield at the revivor doesn't leak.
you gotta post it to youtube and then, copy and paste the link into a post
usually washer fluid noise is one of the 2 pumps, you can replace them by removing the battery and I think the battery plate, unbolting the washer tank and let it drop then you reach up from under /behind the liner, they just pop in and out with a grommet fitting a new aftermarket pump runs about $30 or so last time I checked. tight fit up in there but it can be done.
one pump is for the rear and one is for the front. don't remember which position top or bottom.
My question is, does the pump put enough washer fluid onto the window when you activate it?
iboughtatahoe23
iboughtatahoe23
Does filling the front fill both tanks or is it one tank two pumps?
Malachismith
