Anyone have a door fill up with water?!
KMeloney
KMeloney
Yes it will drain hen the door is hut like it should, instead of build up and only drain when the door is opened.
Yes, it drained when shut and open after I drove it and stopped the truck -- but obviously DIDN'T drain while it was sitting parked for 2 weeks. That's the part I don't completely understand. Either the seals JUST failed, or the seals CAN'T drain at a certain angle, or it required me to slosh the water around in such a way that got it to start draining, or... Who knows what. All I know is that it can't be a good condition.
Modded
That Guy
I just went and looked at mine and don't see a drain, where is it?
Tcwhite
yes this has happened to me on both rear doors. Somehow the drains on the bottom get plugged with trash. I stuck a screwdriver threw enough to release the water. One time it was filled at least half way up the door after a heavy rain.
BogeyBoy82
The Woodlands, TX
Better in your door than in your headliner with the good ol leaky GM sunroof. Never forget after it poured for days driving my old truck (not parked in the garage) to a job interview all suited up and having water pour out from the sunroof soaking me.
900sub6.0
Alberta, Canada
The window seals are not designed to be completly waterproof. The window is movable. Here is a pic of one of the drains on the right rear door.
Modded
That Guy
Thanks, now I will make sure mine are good to go.
KMeloney
KMeloney
I'll post a follow up today when I get the truck back, but the tech did call me yesterday and mentioned something about an "air deflector" (or something to that effect -- again, I'll confirm the proper term later) blocking something...
Sounds to me like there is a piece in the door that became out of position and maybe blocked the path down to the drain(s) in the bottom of the door. Makes some sense.
As soon as I get the truck back, I'll get a confirmation of exactly what the different parts are called, and what happened to lead to the condition.
ProStreetCamaro
Alright cleaned mine out and water poured out of both rear doors. Then sprayed WD40 up into the holes to help displace any moisture thats in there. I may end up drilling a few extra holes down along the bottom to promote better drainage in the future.
KMeloney
KMeloney
Whoops -- Got it a little wrong. It was a "water deflector" that got stopped up in the door. They cleared it. Not sure if they "replaced" it or just "cleared" it, but it had gotten clogged with crap, apparently. So, hopefully I'm good to go for now.
PRCS
