Anyone moved the positive fuse holder on battery to elsewhere?
Denaliz
Frisco,TX
im in the middle of knocking out a Big 3 Upgrade and noticed my 2011 Yukon Denali has the fuse holder on the battery terminal post (positive) vs on the firewall.
I'm going to need to move this to make run for multiple 1/0 runs for amp, Big 3 upgrade and new after market battery terminals
Where can I find a mega fuse box and relocate this I guess to my firewall vs directly on top of the battery?
Including pic to help better understand . (Pic borrowed but still same setup)
08grey
Why not big 3 right on the last pin. Seems easier to me.
Denaliz
Denaliz
Frisco,TX
I'll need to cut the power battery terminal as its crimped directly to cable to feeds under the SUV
Jason_S
Bussman makes a number of fuse blocks. If you just want to relocate just that one fuse, Bussman makes a single fuse folder that can mount to a flat surface and will hold a fuse of that capacity. You should be able to find one at most chain auto stores. I believe that the one I used on a previous vehicle came from Summit and I got the fuses from the auto parts store.
EDIT: found it here: https://www.summitracing.com/parts/bss-hmeg
Denaliz
Denaliz
Frisco,TX
Any chance you can resend that link? Doesn't go anywhere on my end?
I've seen in older NNBS Yukons/Tahoes it's fixed to the fire wall and power cables are run to it. That's what I'm needing to do.
The positive battery terminal is a large multi point terminal and built for that specific mega fuse block to attach to top of battery. ****** design if you ask me.
I want to move it back to firewall and run better 1/0 power cables to help the electrical system and supply a better ground than just from battery to engine block.
Thanks in advance
Jellis02
