Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
That’s not where you do it. You remove the column trim and turn the steering wheel to the side and slide a small flat head into the slots on either side and pull up to pop the spring. It’s a bit hard to describe but you do not poke holes in the steering wheel.
Every instruction I’ve read so far and vid show on the Yukon’s to pop through those holes.
the Colorado/Canyon you rotate the wheel, take off the column cover and insert a screw drive at the 6 o’clock position. (But you spin the wheel so it’s upside down). And that pops the air bag off
Poking holes in the steering wheel is the "I don't know what I'm doing YouTube certified" way. This guy basically shows the correct way. He doesn't mention the column trim needs to be off but you can see that it is. It works better to slide the screwdriver in the slot he shows and then pick up on the screwdriver basically using it as a pry bar to push down the clip on the airbag. You do have to do both sides.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
